2003 Town and Country Lxi lost electrical after jump start
Old 03-16-2014 | 08:08 PM
Traci Rattman's Twister Smith's Avatar
Exclamation 2003 Town and Country Lxi lost electrical after jump start
I mistakenly left something plugged in the outlet that is directly powered by the battery, overnight...in the freezing cold; well, tried to start it today and, you guessed it, she just sat there and ticked away. So, I had someone give me a jump once I realized that my charger had been plugged in and it must have drained the battery. She started right up on the first try once the jumper cables were hooked up, everything seemed to be okay and thats when I realized that I lost EVERYTHING. I lost power to everything that relies on power, my windows, my side doors, my seats, my windshield wipers, my control panel, my back hatch...everything that requires power no longer has it. I have no clue how to figure out what went wrong. Could it be a blown fuse? How do I know which fuse it would be? Maybe a relay? How do I know which relay? Any help here would be great!
Old 03-17-2014 | 01:41 AM
bust out the owners manual it will have the brake down of the fuses relay wont cause this Fuse blown from the outlet and or some one jumping the battery wrong.
Old 03-17-2014 | 01:20 PM
Question So check the fuses?
I know that it wasn't jump started wrong, so should I just check the fuses? Is there one main fuse that runs everything like that? Or will I be replacing all of the fuses?
Old 03-17-2014 | 09:43 PM
get a test light and check the fuses
Old 03-18-2014 | 01:49 AM
Raptor 07's Avatar
Sounds like the BCM took a dump. Disconnect the negative battery cable for 5 minutes. This will reset it. Fuses 19, 20 (40amp), 24 (20 amp) and 14 (15 amp) feed it power.
Old 03-18-2014 | 04:15 PM
Talking You all rock!
just wanted to give you a big THANK YOU!! I did exactly what you both said, I took off the negative side of the battery and checked all of the fuses while waiting to hook the battery back up and unhooking the battery solved the issue!! I am a very happy girl!! THank you very very much!
Old 03-19-2014 | 12:06 AM
Raptor 07's Avatar
Great news. It's a cheap quick fix that often works.
kurt40
01-08-2015 03:00 PM
tonicollette
07-10-2014 02:56 AM
ktrent
03-30-2012 07:33 PM
coolen
09-11-2011 11:51 PM
cursichella
07-14-2010 05:22 AM
