2003 Voyager sputtering and backfiring
Old 09-11-2007 | 09:55 PM
rayoto's Avatar
Default 2003 Voyager sputtering and backfiring
Hello all,
First of all thanks for your valuable insight on this forum!!! Because of you guys I was able to successfully clear the dreaded "Evap Large leak, Small leak" codes on my 03 voyager 3.3 flex-fuel. I actually found the hose going to the black box on the drivers side had a broken clamp. Once replaced, the code went away after 3 restarts. I am having another problem though and it is not producing any codes. When I begin to accelerate the van sputters and backfires, almost as if it were going to stall. I replaced the plug wires but no effect. Should I go for the plugs next..maybe the EGR valve????
Thanks for your help again.
Old 09-13-2007 | 09:58 AM
rayoto's Avatar
Default RE: 2003 Voyager sputtering and backfiring
Hmmm.. No replies, Shocking!!! I replaced the plugs and the problem went away in case anyone is interested.
Old 09-13-2007 | 05:54 PM
WYOCHIMNEYSWEEP's Avatar
r&r plugs
jmichalec
04-13-2014 05:59 AM
wire.nut
11-30-2011 04:52 PM
LemonSebring98
04-17-2011 09:42 PM
sparkers69
03-12-2008 11:44 PM
GreenCar
01-12-2006 03:56 PM
