2003 voyager WON'T START
Old 01-15-2012 | 07:34 AM
caolan's Avatar
Default 2003 voyager WON'T START
HI ALL, Our 2003 voyager 2.5 D, Won't start when you clutch it but will start on a jump, the clutch is sliping a bit would this be the cause ??
Old 01-15-2012 | 09:14 AM
booke23's Avatar
By clutching it I assume you mean pushing/towing the car up to about 10 mph putting it in 2nd gear and letting the clutch out. If so most modern cars won't start by by this method.
The ecu won't inject fuel until it detects the starter being activated and the crank shaft position sensor detects at least one revolution of the engine.
Old 01-15-2012 | 11:29 AM
caolan's Avatar
you have to push the clutch in to start the car and when i clutch it it wont start, but i rolled it and it jumped started
Old 01-16-2012 | 01:49 AM
kdm3170's Avatar
1 of the clutch switches may have gone bad or the connectors have come loose. theres a clutch pedal interlock switch and a clutch pedal upstop switch. i assume both conenctors are just 2 pins, disconnect the connectors and check for continuity with the switch in/out
[IMG] Uploaded with ImageShack.us[/IMG]
Old 01-16-2012 | 09:52 AM
caolan's Avatar
thatk's for the reply,ibut can't see were this is located is there another photo?
[IMG] Uploaded with ImageShack.us[/IMG][/quote]
Old 01-16-2012 | 11:57 AM
kdm3170's Avatar
its attached to the bracket the clutch pedal is attached to, take off the trim panel under the steering wheel and the panel behind that.
Old 01-17-2012 | 03:16 PM
booke23's Avatar
Sorry, I got the wrong end of the stick.....I didn't know you have to push the clutch in on the manual to start it as mine's an auto.
The switch on the pedal sounds like its worth checking.
Old 01-17-2012 | 06:35 PM
pestilance's Avatar
switch on pedal will prob have function for the cruise controll to.
Old 01-20-2012 | 03:35 PM
caolan's Avatar
thanks so much for the replys, turns out to be the STARTER so again thanks
nottmtrucker
12-01-2019 03:45 PM
kurt40
01-08-2015 03:00 PM
clsals
07-15-2011 10:21 AM
jasone6789
01-07-2011 12:52 PM
possumfat
10-17-2007 09:35 PM
