2004 Grand Voyager light switch illumination bulbs help!
Hi, i have a 2004 Grand Voyager and the lights that light up the light switch panel are not present, im having trouble tracking some down an also what sort go in there. Could anyone tell me which type an where i could get some from?
Im in the uk
Im in the uk
Try Maplins, Radiospares, A.C. Farnell in that order. You'll need to find the type of lamp, eg. MES (Miniature Edison Screw), bayonet type, side contact etc., apart from the voltage which is likely 12volt nominal. There are lots of them! I even have some micro-miniature bayonet type I 'acquired' when I worked for Tandberg that are about 3mm. long. A sample to show the supplier is a good idea, otherwise a picture from a service manual. If you can find a scrapper you could raid it for lamps.
Leedsman.
Leedsman.
- You should double check the above yourself, I invested just enough time to show you where to look for info, best of luck !
Thanx for replying so quickly but unfortunately it's not the cluster as shown on the vid. It's the switch panel that the headlight dial is on. Also the door buttons. I think there's been a distinct lack of maintenance on my GV. I've only had it a week so I'm trying to iron out a few ****les.
My answer was to [#1] Dan0678 whose question was about the bulb type
In your case Oxford, if you have tested the switch and the switch is definitely faulty go to a scrappers or get a warranted second hand one for £20 here. If you mean all the door buttons and dials are out are you sure its not just the dimmer is switched completely off. Best of luck M8 !
pervoy98
10-02-2014 03:34 AM
Vmaxxer
07-25-2014 04:08 AM
GrahamLemon
03-04-2013 07:54 AM
rattle_au
01-27-2010 07:08 PM
