2004 T&C P0700 transmission issues
Old 01-10-2008 | 09:33 AM
luu5's Avatar
Default 2004 T&C P0700 transmission issues
Hi all,
I purchased few weeks ago 2004 T&C LX with 74000 miles from Ed Voyles Chrysler in Marietta. After driving some 800 miles the check engine light turned on. I checked the codes with power on-off cycle and ended up getting P0700.
The whole story is as follows. Our driveway is steep downhill, so when leaving the house we have to back up very steep for some 40 feet. And most of the time the car is parked on this slope, nose down. Yesterday the fuel tank was very empty and we left shopping. After backing up the check engine light came on with a beep. I though that it might be because of little fuel and akward position the car was for last 10 hours. I filled up the tank but the light stayed on. Then minute after leaving the gas station the car stalled at the traffic lights, the engine just died. I started it again without a problem. And it has not stalled since, but the light is on.
I have no previous experience how T&C should feel like being backed up steep hill etc, so I amnot sure it should feel. But to me this car feels heavy going up, it is not like any sedans I have had on same slope.
Now, it came to my mind that there was some sort of hesitation (and noice?) from front when we started going forward after backing up. Like front tire scuffing on wheelarch as I had the steering full lock to left, so I though no problems. May be something really broke... yikes... There has always beenslightwhine from somewhere, and the whinegoes higher (and away) when rpms rise, and on idle the sound of exhaust is sometimes little bit like lazy V8, not that low though...
What could be the issues with transmission?
As the car has some sort of warranty for engine and transmission for 2 months/2000 miles I guess I need to take it to them.
Old 01-10-2008 | 10:44 AM
Default RE: 2004 T&C P0700 transmission issues
the p700 code is just an indicator that the tranny computer will need to be scanned for the correct codes.
Old 01-11-2008 | 06:34 PM
luu5's Avatar
I will take it tomorrow to dealer. Let's see.
Old 01-13-2008 | 08:17 AM
luu5's Avatar
The scanner show 1776. Unfortunately they could not tell if it is covered by second hand warranty. May be this Friday I will have time to go back again, luckily the car will stand at home until that.
What could be symptoms of that solenoid/valve problem?
Old 01-13-2008 | 10:05 AM
moe's Avatar
moe
sounds like a valve body issue,thats good because the trans doesn't have to come out.repair can be done incar.let us know
Old 01-13-2008 | 12:12 PM
luu5's Avatar
Is this valve body problem on/off type of problem? I mean when it triggers does the car go to limp mode and then after restarting all is ok? Or can you feel it somehow while driving normally?
What causes the failure? Age, lack of ATF oil change, driving style something else?
Yesterday we did 75mph without a problem, but I am not sure if when it goes to limp mode what will happen...
And can it cause the car stalling?
So many questions... I will keep you informed.
Old 01-22-2008 | 03:43 PM
luu5's Avatar
Dealer called me and told it should be fixed by flashing the controller with new software. I hope it will be.
Old 01-23-2008 | 07:19 PM
karayj's Avatar
I have the same code +P740 let me know the cost jayvette75@yahoo.com to flash at the dealer
Old 01-24-2008 | 09:50 AM
luu5's Avatar
Not cheap $96.60. And no way of knowing was something really done, or just a code cleared... Paranoid, no.
Old 01-26-2008 | 08:07 AM
Rick99's Avatar
First off, you shouldn't be paying for a flash to fix a problem unless the dealer can show you a TSB (Technical Service Bulletin) identifying your problem and prescribing a flash to fix it. In other words, if Chrysler didn't design the software update to fix your problem, it's not going to.
As for the P0740, this is most likely a worn out torque converter clutch. In theory it could be a hydraulic issue, but the converter clutch is a common failure. Unfortunately, it requires removing the transmission to replace.
