2005 3.3l v6 abs problem
Hi,
I have 2005 voyager and abs warning light is on.
I try read faultcodes but can't get connection in abs module.
I disconnect abs module connector and measure that +12 voltega and ground come in module, i also measure all 4 abs sensors and those are ok
can i remove CAB module and try another module, or is there something what i should know when remove that cab module ???
Or is that so simple that i open those four bolts and remove CAB ???
BR, Timo
BR, Timo
I think i found reason why abs lamb is on
I measure those sensors again (with oscilloscope) and notice that left front sensor are more than 500mV lover dc offset than other sensors.
Other sensors have abt 1.5V offset and this left front sensors have abt 700 mV
controller do some selftest when power is on, right?
do anyone know how controller do that selftest in sensors, if controller measure sensors DC offset and that one sersor offset is not correct --> abs lamb is on
BR, Timo
BR, Timo
jimmy154
12-14-2019 10:45 PM
ChiefsChick
12-17-2014 08:22 PM
