2005 Chrysler Voyager 2.8 CRD LX P1130/start problems
#21
Voyager needs key turned many x's b4 starts???
Have a 00 Chrysler Voyager 150K miles. About a week ago, I noticed I go to turn on the van, turn the key, sounds just like a dead battery, one turn of the engine or 2, maybe less, then nothing, try again, engine turns over again or not at all, 3rd time, sometimes turns right over or nothing, etc. but will always (so far) eventually turn over & run like nothing happened. Drives normal, the lights, controls are always lit up throughout the ordeal. Have no idea whats going on?? Battery was replaced 6 months ago.
Sometimes it pops over on the 1st key turn, but it seems to be more & more consistently taking a couple times to start. Any thoughts?? bad ground?? I did have issues with the key not wanting to turn a year ago, nothing lately, could it be a ignition switch?? Sensor?? Any help, its getting cold in MN, dont want to be left out in it!!
#24
Did anyone get to the bottom of this as my 2003 2.5 DRC with 84k miles has started this, always starts from cold, leave for 1/2 hour when hot and no chance have had the Cam Shaft sensor replaced but have been told on mu other post that the Cam and Crank sensors work as one, so am waiting for delivery, I do wonder if I have a real live Gremlin?? When starting after an Hour it goes first time drives great plenty of power
#27
Common rail pressure relief valve fault.
Hi all, Thought i would share my recent experience with you.
I have been having problems starting my Grand Voyager 2.8CRD for some time and decided to test my pressure relief valve a while ago. Please see video. Its a really simple test, you just need some clear tube, a small bottle and something to block off the pipe removed from the valve.
As you can see from the video the valve was opening on cranking and engine idle once started. This it shouldn't do.
I eventually got around to changing the valve this weekend as it had got a lot worse and even embarrassing trying to start it. It now starts 1st time very well and I do not have to use the throttle while cranking anymore. Also I have noticed that i am not getting lots of smoke on acceleration as I did before.
#28
Good answer to starting there from drisaacs and an easy test. Lack of pressure in the fuel rail that has this valve, injectors leaking just off the rail and the rail pressure sensor culminate on this fault. Its a wonder the engine wasn't cutting out under load or was this the next stage. Also this loss of smoke under acceleration is interesting.
#29
Many thanks
Andy
kkc
17
08-29-2015 01:32 PM
Jacob25crd
59
10-18-2012 04:30 AM
davoy
02-17-2011 04:20 AM
