2005 town and country ABS light
lights been on for over a year now. scanned codes and it was passenger side wheel speed sensor. replaced it and reset the light. was fine for about 10 miles and light came back on. scanned and find this code D0000885A. I can't find any info about such a code. cleared the codes and it comes right back on upon start up without even driving. all wheel sensors are working. my scanner says battery low, voltage out of range.
any help, battery starts the car, so wondering if there is something I'm missing. thanks
You should [proper diagnostic scanner] get a B1676 code.
Try the 'key dance' do you get a B1676 in your dash ?
That would set when the Anti-Lock Brake System (ABS) module detects system voltage is less than 9v or more than 19v for more than 8 seconds. In other words if the battery voltage is too low or the alternator is not charging properly.
Thank you. I do not get any other code just the 0000885a. I did notice that I have a broken positive battery cable end. its still tight on the battery post, but I'll replace it and see what happens. I read that perhaps its a corroded wire under the fuse box or a corroded fuse. I'll check it out tomorrow and see if anything looks corroded. What could it be if that's not it? Thanks again
