2006 Gran Voyager red light on dash
Old 08-22-2013 | 10:45 AM
jeremydixon's Avatar
Default 2006 Gran Voyager red light on dash
2006 Grand Voyager
Red light PERMANENTLY illuminated on the dash under the temp gauge.
Car is running fine. I have the grey key.
Have searched and discovered a possible like to a SKIM issue.
I have tried locking and unlocking with key and spare key on both drivers and passenger door. Also on boot / trunk.
I have also tried hitting the dash and doesn't look like a loose connection.
I have done the on off, on off key turn and the system reports no faults.
Can anyone help me with this?
Old 10-03-2013 | 08:16 PM
Newtonn's Avatar
Have same prob myself... Still trying to find what's causing light to appear.. I also have the immob light on and also the airbag...
Old 10-04-2013 | 03:25 AM
doug45601's Avatar
Bad clock spring.
Old 10-04-2013 | 07:07 AM
Newtonn's Avatar
Originally Posted by doug45601
Bad clock spring.
Thanks Doug.... You could be right.. Will be attempting to pull the codes over the next few days to confirm....
Old 10-04-2013 | 09:10 AM
Breaking300's Avatar
The clockspring is probably the culprit...
CLOCKSPRING for 2003 Chrysler Voyager|5082050AC
It's part #2 in the diagram (it's the same part on your car as well, I checked)
Old 10-05-2013 | 11:16 AM
Newtonn's Avatar
Thanks - will definitely check that out. however it also looks like I might have aftermarket alarm installed - that may be the reason for the red light on the dash that isn't standard ...!!!
debbieking
11-20-2018 09:15 PM
GO PATS
12-11-2012 09:53 PM
CWH
05-02-2008 06:35 PM
trev0006
11-14-2007 03:55 PM
Racinfan83
12-11-2005 12:50 AM
