2006 Town & Country 6 Cyl. 3.8 L - Instructions how to replace radiator ?
Old 04-30-2010 | 02:45 PM
chamuko1967's Avatar
Default 2006 Town & Country 6 Cyl. 3.8 L - Instructions how to replace radiator ?
I've got a 2006 Town & Country 6 Cyl. 3.8 L need to replace radiator; can anyone share any information, weblink, youtube videos, pdf. file, etc.. explaining the process of replacement ? It has a crack on it and leaking really bad. I googled it but found crappy weblinks with barely any good information on it...
chamuko1967
Old 04-30-2010 | 09:18 PM
GAS ENGINES
Fig. 1 - A/C Condenser – 2.4L/3.3L/3.8L Engines
1 - A/C CONDENSER
2 - AUTO TRANS COOLER TAPPING BLOCK
3 - UPPER CONDENSER MOUNTING BRACKET (2)
4 - RADIATOR
5 - LOWER CONDENSER MOUNTING BRACKET (2)
1. Disconnect negative cable from battery.
2. Remove radiator upper crossmember support. (Refer to 23 - Body/Exterior/CROSSMEMBER, Radiator - Removal) .
WARNING: Do not remove the cylinder block plug or the radiator draincock with the system hot and under pressure because serious burns from coolant can occur.
3. Drain the cooling system. (Refer to 07 - Cooling - Standard Procedure)
4. Remove the radiator fans. (Refer to 07 - Cooling/Engine/FAN, Cooling - Removal)
5. Disconnect coolant reserve/recovery hose.
6. Remove vapor purge solenoid from mounting bracket.
7. Disconnect upper and lower hoses from the radiator.
8. Lift the A/C condenser straight up to disengage the lower A/C condenser mounting brackets from the radiator. Separate the condenser from the radiator by lifting upward to disengage from lower mounts. Allow the condenser to rest in front of radiator.
9. Radiator can now be lifted free from engine compartment. Care should be taken not to damage radiator cooling fins or water tubes during removal.
Old 04-30-2010 | 09:34 PM
GAS ENGINES
1 - A/C CONDENSER
4 - RADIATOR
Thanks for your answer...I can see in your explanation there are references to Figures & chapters (Refer to 07 -Cooling...), etc...anyway I can get these details (figures) ? I'm pretty green and "how to's for dummies" with figures should help me start rolling...
Thanks !!
chamuko1967
Old 05-01-2010 | 07:51 AM
dont worry about hot to drain the coolant it will come out when u remove the hoses
everything else is self explanatory
Old 05-03-2010 | 12:32 PM
Might want to buy one of these:
http://www.haynes.com/products/productID/116
chrysler2001
12-31-2014 12:48 AM
Navster75
03-22-2014 07:12 PM
rsimonson
05-13-2011 10:46 AM
kytcfan
02-22-2011 10:10 AM
gpatel
11-04-2010 05:34 PM
