2006 Town/country tour. starting problems
I am having problems with my van it's a 2006 model with 10,600 miles on it. I went to start the van and it cranks but won't catch. Finally after a number of attempts it starts rough and shuts off. Chrysler dealer comes up with these codes p0335,p0627,p0129,p0300,p0339,. They reset and comes up with these codes0335,0339,0129. they remove pins from pcm and found short circ to 12v supply harness near pcm. no output from cranksensor and no response when replaced and pcm reconnected.they reprogrammed,car starts. Get the car back using SAME KEY used in repair and car stalls,back to dealer.They hold the car to do check and after 4 days I go to pick up the check engine light comes on (SAME KEY) but car runs.computer check found failure at pdc.
RE: 2006 Town/country tour. starting problems
the dealer reprogrammed my van and told me they ordered a new power distribution unit for my van. It over one week and the van stalled check engine light flashing. Called the dealer today and the power dist. unit suddenly appeared. go figure...my first chrysler and my last..there is no reason that an auto with 10K miles should be breaking down....NONE.
got the car back today changed the ipm over to fcm had code u-110-c car started drove a little parked for one hour went to start cranked the first time, second time cranked and sputtered the third started with some rough idling. back in the shop again.
10-14-2006 07:18 AM
