2008 T&C - cannot remove keyfob from ignition with the car off. Stuck in ACC position
I have a 2008 Town & Country Touring. I searched the forums here but cannot find any threads on this..
When we stop the car and put it in park, we can only turn the key one notch over to ACC and not far enough to remove the keyfob. I have figured out that i have to play with the large silver button/switch on the shifter **** to eventually get it to "click" and then we can remove the key. The Shifter **** seems to be the reason for the problem, so is there a simple solution (part i can order and replace)? or do i have to pay out my ying-yang to get this fixed?
Ive been dealing with this for several months now. My wife hates it. I realize the fiddling with the large silver button on the shift **** will eventually make it worse.
Thanks in advance!
Thanks in advance!
Thanks in advance!
Thanks in advance!
I'm not denigrating your repair abilities. I'm just saying to think and realize what you may be getting yourself into. You wouldn't want your newly repaired shifter falling apart when you're a hundred or so miles from home, or suddenly having the steering wheel lock up as you're on the expressway.
tbird2340
02-19-2020 05:41 AM
latreto
01-30-2007 11:12 AM
karpond
01-26-2007 10:21 AM
