2008 T&C MyGig display screen messed up with lines & dots
Sometimes the MyGig display screen gets messed up with lines and dots all over it, like the display
is going bad.
I believe this happens when the key-fob is not pushed all the way into the ignition or it is tilted a bit
in the ignition. There is some kind of interference.
Once you push the key-fob all the way inside the ignition and straighten it out the MyGig display screen
corrects itself and goes back to normal.
Hopefully Chrysler will have a recall on this and fix the ignition slot to hold the key-fob better.
Don't forget, Chrysler, we typically have 2 - 6 other keys dangling on the other end of our key-fob
which add up to a couple of ounces of counter weight!!
Thanks and see you out there,
Loki Sunrider
is going bad.
Loki Sunrider
CharlieHigh
11-21-2017 07:21 PM
Gary25
03-03-2012 11:18 AM
ARMY DOC
06-08-2011 09:32 PM
