2010 Town and Country Touring
![Default](https://www.chryslerforum.com/forum/images/icons/icon1.gif)
Good morning!
I'm somewhat new to the town and country world and just purchased a used one. I went to check my oil, the dipstick was stuck, and I managed to break off the top. Because it is used and that was stuck it makes me wonder if it was the original/ correct one for the engine. How can I go about finding what the dipstick length SHOULD be on this one? It's the 4.0.
Thanks for your help!
![Stick Out Tongue](https://www.chryslerforum.com/forum/images/smilies/tongue.gif)
When I snapped the handle off of an '06 charger 3.5l, I found a replacement handle at a salvage yard. What I found is the handle is simply pinned into the dipstick and the handles are consistent in the length from the pin to the seat. I picked up a chrysler oil stick and pinned the new handle on the original metal dip stick. To keep the new handle from sticking, I removed the o-ring and very lightly sanded the handle by the o-ring and then replaced the o-ring.
My 2009 Town and Country with a 3.8 did the same thing. What happens is that the o-ring swells and gets stuck in the tube. The plastic handle is not tough enough to bring it out and breaks off. I used a small drill to drill down into the plastic and was able to hook the pin with a bent wire piece and pulled the old one out with a pair of vise grips. l was unable to find an aftermarket replacement for my specific vehicle but they are available for the 2007 with a 3.8. That dipstick fits perfectly and though it's not "identical" the distance from the top to the full and add marks are the same. I found it at O'Reilly Auto Parts. It is a Dorman part, I don't remember the part number but just look it up for a 2007 Chrysler town and country with a 3.8 and compare it to your old dipstick once you have it out. I believe that you will find it a very suitable replacement.
tucsonflash
02-07-2013 03:21 PM
juliemarulie@hotmail.com
09-01-2010 07:27 PM
