2015 AC Problemas
2015 AC Problemas
2015 Dodge Cara R/t 3.5l
Low side 80 psi at engine off with engine temp 195. Low side pressure 35ish at idle engine temp 195. Car idle at 3k low side pressure drops to 15+/- engine temp 195.
Rear air warm, passenger air warm, drivers side coolest.
Low on gas? Opinions needed. What should low pressure read at idle?
with your gauges,hi & low sides connected, turn air on,rev engine,see if low side goes to 0,if so,the Expansion Valve is defective, if system is working correctly, hi side will be bout 175 - 180, low side, 30-35 at an idle, have to know what the hi side is doing
kkc
17
08-29-2015 12:32 PM
