2015 T & C Red Lightning, Check Engine & Traction Control
Hi All,
My wife's car was working fine until yesterday and all of those errors mentioned in the title came on last night. I used a OBD and the error code is P0107. Could it just be the MAP sensor like I've looked online or something more serious? I ordered a new sensor that should be here in a couple days.
Please advise.
Please advise.
What condition is the battery in and how old is it? Chryslers do not tolerate low voltages and tend to act weird and light up random cluster lamps and throw seemingly unrelated codes? With the engine not running (for at least 20 minutes) the battery voltage should be around 12.4 volts; anything under 12.2 volts indicates a weak/failing battery.
Battery is fairly new. Her old battery died last year and just bought a new for her and replaced it. I just got a watt meter and will be checking her fuse box later when I'm off work. So you think the MAP sensor should be fine and won't be the issue?
