97 tand c runs fine then shuts off
If the fuel injectors are dead too that points to an automatic shutdown due to loss of crank or camshaft sensor signal. Could be the sensors themselves, poor connections or the wire harness carrying the signal. If it's only no coil power it points to loss of power out of the PCM meaning a bad wire to the coil, poor connection or a bad PCM.
The OBD fault detect system is far from fool proof. Components often fail without generating a code and a check engine light.
Gringo Starr
08-12-2016 08:37 PM
eembree
08-29-2009 09:50 AM
cajunsprt
9
01-25-2008 02:06 PM
