97 Town and Country crank bolt snapped
Old 06-08-2012 | 06:14 PM
dh1989's Avatar
Default 97 Town and Country crank bolt snapped
I have a 1997 Town and Country 3.8 which has the crankshaft pulley bolt broken off inside the metal shaft that the pulley slides onto. The end of the bolt is about 1" inside. I am trying to slowly drill it out but am not sure how long the bolt is or if there is room behind where the bolt seats so I don't drill into and damage the crankshaft.
Is there a space behind the bolt I can safely drill through? Does anyone have any other ideas on how to get it out. The pulley is off and out of the way (not that it made much difference).
Any help is greatly appreciated.
Thanks.
Old 06-08-2012 | 11:14 PM
TNtech's Avatar
Is it cross threaded or did it just break off because of tightening? You're not going to hurt the crankshaft as long as you keep your bit centered. There is about 3/4" of space after the bolt. The whole bolt is about 5 inches I think. Get an extraction kit. It has drill bits and extractors that bite into the drilled hole when you turn them. Use lots of rust penetrant and tap with a hammer intermittently to loosen the threads from each other.
http://www.handsontools.com/Hanson-5...et_p_9139.html
Many parts stores sell these
Deadly600hpAWD47
09-20-2011 03:29 PM
NisCAPE
06-22-2008 05:24 AM
azev314
05-28-2008 02:55 PM
3.3lxbluevan
04-26-2008 11:10 PM
playboy00786
10-12-2007 07:02 PM
