99 Grand Voyager - Front Blower not working
Old 03-16-2010 | 12:30 PM
sjbilton's Avatar
Default 99 Grand Voyager - Front Blower not working
99 2.5 TD Grand Voyager - discovered last night that the front blower fan does not respond to any switch position - according to my wife it has been like that for a few days, some days it works some not!
Fuse & relay are okay so where to look now?
I've seen mention of the blower control module - what/twhere is it - easy to test/replace?
Steve
Old 04-21-2010 | 04:44 PM
sjbilton's Avatar
Someone must have an idea - anyone got a wiring diagram / workshop manual in pdf that they share?
Ta
Steve
Old 04-26-2010 | 06:46 AM
lonegum's Avatar
Hi Steve, I had a problem with my blower speed controller and had to replace it. I found it behind the glove compartment (which had to be removed) fixed into the blower housing by two screws, and a multi-wired plug connected to it. Very easy to change. Mine is a 2003 model though, so don't know if it is the same. Good luck.
Old 04-27-2010 | 02:48 AM
sjbilton's Avatar
Thanks for the reply - how was the problem dianosed to be the controller? Did you need a scan tool or did you just start replacing smaller items?
Cheers
Old 08-11-2010 | 12:08 PM
sjbilton's Avatar
Ironically the fan works most of the time during warm weather, and when it is cooler it mostly doesn't - does this point to the motor rather than the controller? Is the motor serviceable or is it a replace only part?
I'd rather get it sorted before the autumn comes and find we've no blower for clearing the front screen...
Old 09-28-2010 | 11:21 AM
sjbilton's Avatar
It's getting codl now and the blower has stoped working - does this point to a motor issue rather than the controller - can I test the controller module or do I just need to bite the bullet and buy one?
mwall
09-08-2014 07:49 PM
rastoma
07-07-2009 08:41 PM
dbremer37
11-19-2008 01:43 PM
beamond
06-02-2008 10:01 PM
harryvil
07-30-2007 06:38 AM
