99 Voyager 2.0L Cat
Old 03-05-2010 | 08:48 AM
dcm1971's Avatar
Default 99 Voyager 2.0L Cat
If my Catalytic converter is failing, what symptoms would I expect to see please??
Thanks in advance.
Old 03-11-2010 | 06:05 PM
dcm1971's Avatar
anyone?
Old 03-11-2010 | 07:50 PM
mrfixit454's Avatar
Only experience I have had on a cat was when it was rattling inside. Sounded like a loose muffler clamp. I hear they can starve the engine of power, give poorer MPG and set codes when they plug up.
Old 03-12-2010 | 02:03 AM
dcm1971's Avatar
thanks
Old 03-12-2010 | 09:17 AM
I wonder's Avatar
if it's really bad, then it will start faling apart on the inside and then you will hear a rattling noise like mr... said.
but first you will have a bad exhaust test. too much HC in the exhaust fumes, but that can also mean problems on some other part of the engine.
anyway, the test can be made.
on idling, Cat should be only warm. couple of quick snaps on accelerator should rise the Cat tremperature significantly. also the exhaust fumes temperature should rise and tester should show more HC, but not too much.
if Cat temp. stays low and exhaust shows high levels of HC, Cat is dead and needs replacement.
woodthumb
02-03-2012 05:24 PM
woodthumb
01-11-2012 09:08 PM
bigdaddyfaison
05-10-2011 05:13 PM
huasi87
04-08-2010 09:53 PM
Katiecuppa
10-31-2009 08:17 PM
