ABS help
ABS help
ABS light comes on after I remove front drivers tire to grease Tie Rod. A few days later the Brake light comes on as well . Both lights stay on . Regular Brakes all OK, no leaks , fluid level good, Emergency brake not on.
Pulled the codes from the ABS
- # 10 - ABS Valve Power Feed Malfunction ...could this be from pulling the fuse out to see if that set the light off ??I have no idea what this is ??
- # 2 ABS Left front speed / signal
- # 6 ABS left rear speed / signal
Is the left the drivers or passenger side as it differs depending on where you are ?
Once we cleared the codes BOTH the ABS and Brake light went out and when I drove it they BOTH came back on at the same time
Any idea ??
Any idea ??
brakes spongy 2004 chrysler voyager
Hello Pals., thanks for all your replies.
I have ordered a ECU for the vehicle to fix engine miss on one cylinder. This was diagnosed by Chrysler trained mechanic. The ecu I ordered is from a Dodge grand caravan and had been programmed with the vehicle vin. I am awaiting the ECU. I also have brake issues, soft pedal, drops away with engine running. Have had a previous dealer report from previous owner saying Master Cylinder should be changed and then possible ABS should be changed. Considering all above.
1. with dodge ecu fit Chrysler Grand Voyager. o.k.
2. Will fitting the ECU possibly fix brakes issue.
3. Also Fans behind radiator not working, will fitting ECU fix this issue as well?
Reading posts, it appears Master Cylinder may need replacing.
Cheers,
Thanks for reading.
Cheers,
Thanks for reading.
jimmy154
12-14-2019 10:45 PM
dms3mi
04-06-2014 12:21 AM
dartboy340
09-10-2011 04:02 PM
Gasman
01-24-2011 01:23 PM
