airbag module(acm/ORC)
Old 01-15-2012 | 12:33 PM
kdm3170's Avatar
Default airbag module(acm/ORC)
does anyone know the address and protocol info on the airbag module for a 2002 t/c?
Old 01-15-2012 | 03:21 PM
U would need to be the maker of the air bag module for that info
ANd why would u want or need that info any way?
Old 01-16-2012 | 12:42 AM
kdm3170's Avatar
i'm using the torque app on my phone and a bluetooth obd scanner to get DTC and live sensor data. the airbag light is on n instead of paying chrysler 110 bucks to pull a code or a no name garage 50 bucks to do it, if i can get the address of the module n the protocol it uses the guy who made the app can add it in so i would be able to pull codes from the airbag module for free. n im sure the address n protocol info could b accessed wit the DRB garages have
Old 01-16-2012 | 01:41 AM
TNtech's Avatar
Major chain parts stores usually read the code for free. The code name doesn't always mean that buying a part and swapping it will fix your problem. Just so you know, you're taking a gamble slapping a part on. I see it every day and they most often end up coming to see me AFTER they spend hundreds. They don't give refunds for electrical parts usually.
FYI, they are not charging you money to pull the code...that's an incorrect assumption. There are tests that have to be done to come to the conclusion to replace anything. ESPECIALLY with airbag. You guess wrong you get an airbag to the face and a trip to the ER.
Old 01-16-2012 | 01:59 AM
kdm3170's Avatar
i asked for the price for the code only no diagnostics. 90% of the time when the light comes on its while cornering/turning the wheel, which makes me assume its like all the other major causes ive seen online for the same car, either the clockspring or the squib harness. clock springs only a 35 dollar part and if it came back as the squib should just need to check continuity between airbag connector and the orc connector to see if its the wiring or if the problems inside the airbag
Old 01-23-2012 | 06:07 PM
fattylady's Avatar
Default Chrysler Voyager 2001
Airbag light on have had this on a previous voyager and it was the airbag sensor that needed replacing quite expensive from the dealer. Anyone know a safe solution?
Old 01-23-2012 | 06:40 PM
what solution are u looking for?
ChryslerOwner
11-02-2019 07:29 PM
warrenwels
03-27-2007 01:10 PM
sebring gabbie
03-06-2007 02:39 AM
satanicmechanic
07-13-2006 02:44 PM
silentblinder9502
05-15-2006 01:45 AM
