Automatic transmission only works when it's warm
Hi there.
I have a Grand Voyager 3.8 LE Automatic, 1998, and the following problems has appeared:
Hopefully someone in here knows what to do, or if these problems are connected.
Have a nice day
Jens
- It only shifts into gear when it's warm, which means that the motor must run for five to ten minutes when it's cold before the car moves at all. (There's a small leakage somewhere, hence it spills oil - app. ½ liter pr. month. I check oil every day and fills up, if it lacks). Once warm, there's no problems at all.
- The caracteristic "clicking" sound that usually appears when you shift into gear and just before you stop, only appears from time to time.
- The "device" that regulates the idle running doesn't work. The idle running is therefor set to 700 rpm.
Have a nice day
Jens
Hello Jens. I too have the same Problem with a 2000 Chrys T&C 3.8L. I used a product called "Lucas Transmission Fix", which stated it is "Guaranteed to stop leaks and hard shifting". It did mostly stop the leak, and it did help the shifting problem - for a while - but now I must warm up before it shifts correctly.
I will try changing the Trans fluid & filter, using Mopar Trans fluid (not cheap brand). I will probably add more Lucas Transmission Fix too.
I will let you know if that works.
Hi Bdear
Thanks for answering.
I will try The Lucas Transmission Fix, and see what happens. Moreover i will send the old lady to a Chrysler-wizzard I got connected to. I will let you know if he finds a cure, and I'm looking forward to hearing from you have tried the Mopar
Best regards
Jens
Best regards
Jens
Jens,
Since the weather here is cold, I decided to be "lazy" and just pump out as much transmission fluid as I could using a pump with hose into the dipstick tube. I did not change the filter.
I got about 4 quarts (~4,5 liters, right?) of the old fluid out, and then replaced it with about 3.5 quarts of Castrol ATF+4, plus about 0.5 quart of the "Lucas Transmission Fix". The reason I used Castrol is because there is no Chrysler dealer in my town and the Mopar website - Licensed ATF+4® Brands - said Castrol ATF+4 was approved.
Anyway, this small change made a very big difference in the performance. The transmission shifts just as it is supposed to even when cold. I imagine a proper complete fluid & filter change would be even better, but I am happy until Spring when the weather is better - then I will do the proper job.
Best Wishes,
Bdear
Best Wishes,
Bdear
dm6174
11-11-2009 06:39 PM
marshlk
01-03-2009 04:34 PM
3.3lxbluevan
04-16-2008 04:46 PM
