beeping when driver door open
Old 04-11-2012 | 09:41 AM
Alexmcilwaine's Avatar
Won't let me pm u motlow
  #22
Old 04-11-2012 | 10:41 AM
tommymca79's Avatar
Batyre on north queen street will charge your battery for £1, also my car was losing power for a few days but it's cured itself now
  #23
Old 04-11-2012 | 04:19 PM
Mine has had the issue for a good while now. Keeps draining batteries (tried new battery). Think I need a new ignition barrel as the string or something is broken in it as there is no resistance or spring back when I turn the key
  #24
Old 04-13-2012 | 03:33 PM
ChryslerCares's Avatar
Have you verified that its not the radio drawing power off the battery.
TSB 08-003-08
SUBJECT:
Hard Start/No Start Due to Weak Battery
OVERVIEW:
This bulletin involves checking for ignition off power draw caused by the radio and if
necessary replace the radio..
SYMPTOM/CONDITION:
Vehicle operator may experience weak or dead battery condition. This may be caused by the radio not powering down properly and keeping the communication buss awake causing a parasitic battery draw.
  #25
Old 04-14-2012 | 05:54 AM
I replaced the radio as the old one wouldn't put out any sound. Have had the problem before I changed the radio. Would a faulty ignition barrel cause a battery drain as it seems the spring inside the barrel is broken
  #26
Old 04-15-2012 | 01:48 PM
motlow's Avatar
sorry just moved house had no internet , seems very like ignition barrel/switch you should not hear any bleep when you remove your key unless it is at the auxiliary position , i'll get a look for you if you can wait till this coming weekend
  #27
Old 04-16-2012 | 08:13 AM
That would be brilliant. The ignition barrel has no resistance when I turn the key. To start the engine I have to turn the key all the way round to the right but the abs and handbrake light stays on. I then have to turn the key slightly to the left and the radio comes on, computer comes on and the abs and handbrake light goes off.
  #28
Old 04-20-2012 | 11:36 AM
Are u able to look at it for me motlow?
  #29
Old 05-01-2012 | 11:04 AM
are you able to look at it for me motlow?
provench
10-07-2021 05:42 PM
sleninger
05-16-2011 09:14 AM
ajs42548
04-12-2011 09:17 AM
aavp96
08-10-2010 10:02 PM
Saatu
01-01-2009 12:20 PM
