Brake dust on front wheels
Back in early January I changed the front pads and rotors with Napa safety stop pads. I've been noticing an unusually high amount of brake dust accumulating in a short period of time.Is this normal for the first couple of weeks? The pads were not cheap.
No unusual odors, and other than the dust it seems to preforming normal. The only thing I haven't done is spray brake cleaner; which is my next step.
We get what we pay for :
- my early days asbestos
- then came organic semi-organic or metallic
- now we have ceramic pads
- leave the organic semi-organic or metallic to boy racers, cop cars & commercial vehicles
- ceramic about £60 for 4 dust free corners
Here it's a question of pedal effort. Soft brake pads/shoes will give you a miraculous easy pedal but will wear (and produce a lot of dust). Hard pads/shoes will need more pedal effort but last a long time, and with less dust. So long as the system can lock the wheels (if allowed by the ABS) whatever you use is safe enough. If ceramic pads do the job safely, why not? Less likely to have fading problems with heat too. And $11:60 sounds cheap compared to ceramic discs/rotors!
Leedsman.
Leedsman.
I used work for a company with 650 fleet of cars. We tried hardened pads to reduce the cost of brake pad replacement, it worked, the price of replacing the pads reduced by 30%. However the increased cost of replacing worn out discs / rotors was three times the saving on the pad replacement.
Scotsman4th
08-08-2013 03:34 PM
bgeise
11-30-2012 08:05 PM
Josey_Wales
03-06-2006 04:29 PM
