Centre Console Back Lights Not Working
Old 01-10-2015 | 12:18 PM
The IOD [ignition of draw] controls :
Remote key fob
Radio
Heater blower
Folding mirrors
Central locks
Interior lights with IGN on
The power seats
Taking the terminal off the battery resets the three computers, in this case the [BCM] body control module. So long as it worked for you my friend.
Old 01-10-2015 | 12:31 PM
Daniel Williamson's Avatar
yeah worked for me, thought whilst I was looking at the fuse I would check all the others and make sure none were blown or dirty, either way something worked for it all to work again strange one hey
Old 01-10-2015 | 02:16 PM
The IPM [(Intelligent Power Module) the fuse box] in its own right is the case of many problems. If you look in or in particular under the IPM its often a dirty verdigris laden mess. Its also not as many people assume one layer of PCB, but three layers with one set of metal pins going through all the layers :
Its essentially the point of exchange for all signals coming from and going to anywhere in your GV via the wiring harness, and placed where it can precisely suffer from water and dirt ingress on its hidden bottom out of sight of most people. Undo the two clips and look underneath and you will see several human wrist thickness bundles of harness quietly corroding underneath.
Old 01-10-2015 | 06:29 PM
Raptor 07's Avatar
Thumbs up
ok just letting you know they are all back on again The IOD fuse was with the other fuses under the hood 15A, it looked fine but changed it anyway. I had the negative terminal off the battery whilst looking at fuses so that might have helped but after changing the fuse and connecting the negative back on the battery all is working as it should. nice red glowing needles and I can see my centre console buttons once again thanks a lot guys and hopefully this will help anyone else who has had the same issue
Sounds like the BCM needed a little "caressing". They get a little dodgy now and then. (yup that's a pun).
  #15
Old 01-10-2015 | 07:11 PM
well its one thing working, now onto the next, been looking back at old threads in ref to the power liftgate not working, seems to be that it could possibly be the latch, just looking for part numbers and a part number for the overhead dome light bulbs. not major issues I know but I like to try and get them sorted if I can
Merlecollins
24
10-18-2014 01:21 PM
itakepix
11-04-2010 08:37 AM
Octaneflyer
09-15-2009 10:59 AM
Newtoo300s
09-14-2008 09:23 PM
paul.siwek
07-29-2007 11:31 PM
