chrysler grand voyager won't start
Old 06-22-2009 | 04:22 PM
Merlin's Avatar
the control valve you can see and remove very easy as it's just too screws and the electrical plug. could be an idea to swap that over first if you are getting a complete pump off e bay as it will save disturbing the belt (you make my cringe with the word tippex, lol). We call it a prop valve if you are doing a search.
Best of luck hope it sorts it.
  #22
Old 06-23-2009 | 05:08 AM
ruki's Avatar
Default tipex
Merlin,
is there a flywheel lock up hole? some cars i have done you can put a dowal through a hole and it locks the fly wheel up?
  #23
Old 06-23-2009 | 06:36 AM
ruki's Avatar
Default pump commonality
is this pump common with anything else? jeep 2.8 crd?
ruki
  #24
Old 06-23-2009 | 02:23 PM
Merlin's Avatar
should be the same pump as the jeep would have to check with parts to be sure. There is a locking pin but there is also a mark on the bottom gear. Don't go by the marks on the top gears as they don't line up with anything. The top gears are free wheeling so don't loosen the bolts.
  #25
Old 06-24-2009 | 03:27 AM
ruki's Avatar
Default injector pump
Thanks for that,
Please let me know asap about the pump, there is one i can order on ebay right now.
ruki
  #26
Old 06-25-2009 | 04:01 AM
ruki's Avatar
Default parts sourced
Sourced the parts yesterday and they should be here today. Merlin, is there also a lock up facility on the cam shafts?
ruki
  #27
Old 06-25-2009 | 01:39 PM
Merlin's Avatar
yes there are blanking plugs on each cam shaft cover at the front
  #28
Old 07-03-2009 | 03:59 AM
ruki's Avatar
Default nearly there now
nearly finnished now.
will the car start before i refit the auxillary belt and all of the airbox stuff?
2005Cruiser
08-20-2018 09:46 PM
p0z3r
03-25-2017 11:04 PM
Ellebelle70
02-15-2017 08:41 AM
jbda
Cirrus & Breeze
04-01-2013 12:09 PM
laura
04-11-2010 09:48 PM
