chrysler T&C (2001) power steering
I lost power steering in my van, it was making a loud noise from the steering column. I noticed I was low on fluid so I added some. The noise went away but my steering is very tight, and I am losing fluid underneath.
What are the possible problems and $$ to fix?
Thanks in advance.
I also drove it 3-4 miles that way. Don't know if I could have done further damage...
just added 32 oz of power steering fluid with stop leak additive. I checked underneath the car and fluid was draining onto garage floor significantly.
Help?? Is it as simple as a fixing the leak? Is the pump not functioning (when I turn engine on, fluid level went down significantly) ? What are symptons of rack issues?
Thanks in advance.
i am sure there are multiple areas where the leak can be present, however can we rule out rack or pump issues?
I guess if the pump is cracked, the leak could be there...but it seems that the leak is somewhere else
chryslervan
03-21-2009 11:07 PM
3.3lxbluevan
02-15-2009 08:06 PM
