Chrysler town and country 2004 P0303
I have a 2004 Chrysler town and country (3.3) with 160,000 miles. I got a p0303 code- misfire on number three cylinder. I replaced the plugs, wires, and #3 fuel injector. I also took a multi meter across the coil pack plug wire leads and they seemed consistant in ohms. I also did a compression check with a cheap (harbor freight) comp tester. One time they seemed all about 160 lbs and another time the number three seemed low (100ish). Not sure if the cheap tester was the issue or if the cylinder reads different at different times? Any other thoughts??
I saw online that someone tested a coil pack by taken a multi meter and read the ohms reading across each set of terminals and see if the have simular read outs. Does this tell you anything about the condition of the coil pack? Thanks
Don't know why I haven't tried it before, but I put a spark test light on the #3 wire between the coil pack and the wire. When in drive I get a miss about every 3 or 4 seconds. Put it on another wire and no miss! So it must be the coil pack right? Or could it still be the cam sensor? Thanks for all your help with this.
