Door Lock Problem.
Looks like skim skreem has activated anti-theft with flat battery. Trick is to disconnect battery for 20 minutes. But you can't open bonnet. If you could ....
Try this: using the key lock then unlock the drivers door from the outside, if that don't work try the same thing on the passenger door. If that didn't work then disconnect one battery cable, turn on the headlight switch wait 30 seconds, turn off headlight switch, reconnect battery cable and recheck. Hope this works for you.
Get a new battery on it for starters. I prefer Varta F18 non AGM.
#18
I can't do any of this because ( as I have described ) I cannot get into the car.........
Unless you have some ideas about how to do any of this with all doors and bonnet locked. They would be most welcome.
The Varta battery you mention is only a little better than the Bosch I have, and would get flattened by the parasitic drain just the same. Thanks for the tip though.
#19
Yes in #18, I said so in #17.
Read Chrysler issue workshop manual: pictorial schematics maybe you can get in through.grill etc and save £££. Or someone to photograph theirs for you.
Best of luck. I'm outta this thread now!
#20
Your year same puters.
https://www.chryslerforum.com/forum/...58/#post113025
On batteries general.
Battery Drain? - Voyager 4th Generation (2001-2007) - Chrysler Forum UK
Chrysler workshop issue manuals in Inc hen's teeth CRD.
Index of /pub/chrysler-dodge/manuals/Service Manuals/2005_RG_Town&Country_Caravan_Voyager_Diesel_Versio ns_Include
My early learning phase IOD/ParaDraw.
https://www.chryslerforum.com/forum/...battery-22790/
Chrysler Pulse crazy alternator learning.
https://aviondemand.com/insider/are-...arging-system/
