Engine cut out bicouse OIL temperature sensor
i have a problem with the oil temperature sensor on my voyager 2.5crd 2006. i noticed that when the sensor is hooked the engine cut out, when I disconnect conector from sensor the engine work normally in hi rpm, i replaced the oil temperature sensor and the same thing happens again. what could be the problem?
