engine dies unexpectedly
Old 08-18-2008 | 07:57 PM
MSgt Egress's Avatar
Default engine dies unexpectedly
My first post and I'm in need of some troubleshooting assistance. I have a 1994 Plymouth Grand Voyager with 255K. I have replaced the engine about 60K or so ago (Jasper). It has been running like a top until about 2 months ago. My wife usually drives it and she says she'll be driving along and the engine just quits. The strange thing is no warning lights pop up (alt check eng etc) she puts it in neutral and it starts back up and it is fine. It seems to do it when the A/C is running. If it is off it seems to be ok. It has done it stoped at a light or rolling down the road. Today it happend to her 6 times in the span of 30 min or so. I'm stumped! Does anyone have a clue what could be going on???
Here is what I have replaced recently:
A/C compressor (original one finally gave up the ghost last fall)
Ignition switch assembly (lock cyl and switch) This spring
I appreciate your help
Tim B
Old 08-19-2008 | 08:25 AM
I wonder's Avatar
Default RE: engine dies unexpectedly
my guess:
-one of the contacts on the ignition switch that you changed. try finding it's connections and shake them, see if they're loose.
-crankshaft sensor looses signal when getting really hot. hence, PCM shuts down the engine.
Old 08-20-2008 | 08:47 PM
dodgeman213's Avatar
that happen to my moms car, unfortunately, she had no choice but to replace the engine
auto insurance
Old 08-21-2008 | 06:45 PM
Al B's Avatar
checked battery connections? A poor connection, or excessive corrosion can give these symptoms.
myfirstsebring
11-28-2011 01:44 PM
john777
Cirrus & Breeze
03-14-2008 11:46 PM
jimhild
01-28-2008 12:24 AM
donnyohs
9
01-10-2008 01:04 PM
Ash
Cirrus & Breeze
01-03-2008 09:36 PM
