Factory trailer harness?
Old 09-14-2012 | 01:49 PM
AZ_Ron's Avatar
Default Factory trailer harness?
Hey all... I'm trying to get my 1999 T&C Limited setup for towing a small
trailer, no more than 2k lbs.
I have the factory towing package. Nivomat shocks are blown out, just ordered replacements (OUCH!). Hitch is installed from the factory, Aux tranny cooler, HD radiator, etc. Doesn't seem like the original harness was ever installed, and I've NO idea where to find it.
I've seen references that it 'should' be in a plastic bag in the cargo area, but
aside from the jack compartment, I've been unable to locate anyplace it might be. I did buy the van used several years ago, so it's possible it's just missing.
Any hints on where to look??
Thanks much!!
Old 09-16-2012 | 08:07 PM
woodthumb's Avatar
not much different than what should be available at auto parts store...factory designed to splice into each tail light from above inside lift gate......aftermarket will plug in under vehicle toward rear where connector splits off to each side.....ask or look for quick connect trailer harness to fit your van..... not hard to do if you find correct part...
bettyboop
04-08-2012 12:22 PM
spotmaticf
06-23-2010 09:59 PM
rpdenney
11-18-2008 05:24 PM
georgeo
05-15-2008 10:04 PM
mrrbby
04-30-2008 08:16 PM
