Fault code p1776
Old 01-24-2015 | 04:50 AM
S6Voyager's Avatar
Default Fault code p1776
Help please, just ran a dio test on the voyager and showing the above code, had a look on line but really unsure what it means? Can some one help please?
Old 01-24-2015 | 07:02 AM
tfb's Avatar
tfb
First thing is to check fluid condition and level, then the fault finding procedure can be found here
http://oskin.ru/pub/chrysler-dodge/m...ansmission.pdf
Regards
Richard
Old 01-24-2015 | 07:07 AM
P1776 - Solenoid Switch Valve Latched in LR Position (this is a transmission issue which may involve replacing the valve body and solenoid pack; on some models there is a TSB on this problem so be firm with your dealer / Chrysler).
Old 01-24-2015 | 02:40 PM
mastiff's Avatar
Just had the same thing happen i managed to delete the code and get out of limp mode to get home. Iam going to have a good look in the light and hope its something simple i will update or cry tomorrow.
Old 01-24-2015 | 06:24 PM
the solenoid pack is more then likely need to be changed.
Old 01-26-2015 | 12:01 AM
Nick1981-1's Avatar
yes.. I had the same issue with the fault code.... mine was under drive solenoid problem. needed a new auto transmission solenoid pack on... £800 but it was still under warranty thank god lol
Old 01-27-2015 | 07:17 AM
mastiff's Avatar
Does any one know where to get one and is it a diy job or off to the garage
Old 01-27-2015 | 07:31 AM
tfb's Avatar
tfb
best off ordering one from the US
Chrysler Solenoid Pack: Automatic Transmission Parts | eBay
Regards
Ricahrd
67 Camaro
01-06-2015 09:40 PM
kubick
06-12-2011 09:30 AM
stewartsoftware
04-17-2011 04:22 PM
danielrp
04-27-2008 09:26 PM
danielrp
03-29-2008 05:26 PM
