Fault codes flashing
![Default](https://www.chryslerforum.com/forum/images/icons/icon1.gif)
Does how many times a car fault code flash mean anything. When I check my codes it starts with P1130. Now sometimes this will flash for say fives times. Sometimes it will flash 40 times before going on to the next code. I also wish I could clear the codes. Have disconected the earth lead from the battery, turned on the light, and left it disconnected over night. When reconnecting the battery, fault codes are still there.
year - model - mileage please
A number of auto parts stores will pull codes and give you a printout.
What is the age and condition of the battery? A weak/failing battery will cause all sorts of odd behavior and dtc's
2007, voyager executive cdi, 107000. Battery appears to be nearly brand new.
It's really just weird how the ammount of flashes for each given fault varies each time you test it out, and I was wondering if or what it means.
justplaincornel
12-14-2016 04:23 PM
Gray06TCmb
04-15-2010 06:14 PM
