Fitting a second thermostat - the guide!
Hi folks,
This weekend I decided to follow Leedsman's great idea/guide on fitting the second thermostat to my 2005 GV and it works great!
(See original thread here https://www.chryslerforum.com/forum/...rmostat-20480/
I did a how-to video on it too so if you want to give it a go, it's a nice and easy one to do:
Thanks once again to Leedsman for this solution!
Thanks Andy, brilliant video and a great help to us all. My 2.8 is warming up OK at the moment but you make the job look so easy in your great tutorial that I think I'll add another thermostat before the winter sets in.
Alan
Alan
I'm a consensual objector and happy with the real thermostat at back of engine that was fitted by my son nearly 5 years ago, with my direction of course. Son said he wouldn't go near my car again after that job due to the heated argument he had with it. But he calmed down quickly after white coats from the Looney House turned up. Got a real mechanic on the job now though..
But in all a really good idea to fit the thermostat in this place and I'm sure the dialogue will be in different languages by now.
It was in the post that AndyB linked to and kindly provided by QinteQ https://www.micksgarage.com/search?k...26575&pk=8ca9a
Thanks for the great video. I have a 2012 Grand Voyager 2.8 CRD with the same problem. The cooling system configuration is different though. See below. Does it matter where the second thermostat goes? I am assuming that the 1.5mm hole will allow enough flow so that the thermostat will open, but don't want to assume myself into a cooked engine. Cheers. Joakes from Aus.
Pipe on this model is lower than in the video.
Hose connecting directly to the top of the radiator is easier to access and I would have to drain less fluid. Would it be OK to put the thermostat here?
kajikindorai
01-12-2009 08:22 PM
Chiketkd
02-06-2006 01:02 AM
