flasing climate control lights????
Hi Guys,
after having to jump start my 98 Grand Voyager on the weekend (as per the owners manual) all the little yellow lights on the AC, recir/fresh/, rear wiper etc buttons are flashing. What is this teling me and how do I stop it.
Cheers
Gary
Cheers
Gary
RE: flasing climate control lights????
do this
COOLDOWN TEST ENTRY TO INITIATE TESTS: [ul][*]Set Blower motor ON HIGH[*]Set Mode position to Panel[*]Open all A/C outlets[*]Set Temperature to Cold (Both slide pots if equipped)[*]Depress WASH and A/C simultaneously for 5 Seconds [/ul] NOTE: Prior to start of test, If the evaporator is already cold, the system will fail test. To correct, operate system with A/C OFF and the blower motor ON high for three minutes prior to starting test. RESULTS: [ul][*]All LED's will turn on for 5 Seconds[*]Cooldown Test is running when A/C and RECIRC. are alternately flashing. If A/C and RECIRC. are flashing simultaneously, Cooldown has failed. [/ul]
