Gauge ?
I put a ScanGaugeII into my 2009 T&C. Easy install, no wiring just plug into the OBD port to left of steering column at base of dash. Volt read out but no Oil Pressure, Temp. or Trans. Temp unfortunately. Maybe someone else has figured out how to read the OBDII codes for that information.
Actually there is on CAN BUS vehicles. Before that no, you could not read anything. The Minivans not until 2012 models I think.
Thanks for that info. TNtech. Perhaps then, if the codes are 'transferable', either ScanGauge or someone more capable than I will be able to program those codes into an existing SGII for pre 2012 vehicles that use the CAN BUS.
