Gearbox Coolers. OK with just one conected?
Old 11-09-2009 | 02:47 PM
gareth111278's Avatar
Question Gearbox Coolers. OK with just one conected?
Hi Guys.
A friend of mine has just got her first Voyager. its a 1998 3.3 Auto [standard UK spec].
Like mine it's fitted with the radiator with a gearbox cooler at each end [were they all like this?] I read somewhere that this set up is used on vehicles that are expected to do alot of towing, is this correct?
She has a gearbox oil leak , looks like its somewhere on the front of the 'box. I know that if its those pipes i changed they are VERY expensive.
My question is , " As the car never does any towing is it OK to just connect one gearbox cooler using rubber hydralic hose?? "
Cheers Gareth
Old 06-14-2010 | 10:16 AM
bradleigh1977's Avatar
did you ever get this sorted?
Old 06-15-2010 | 04:37 PM
ettienne's Avatar
If you do not tow anything then the stock factory trans cooler is good enough.
dcotter0579
12-09-2012 11:38 PM
Purbano
09-22-2005 01:58 AM
04-21-2005 10:54 PM
porschefreek2003
03-23-2005 09:39 AM
03-14-2005 09:53 PM
