got tranny but still dont work
#42
Now then, you may take the valve body down, pull the piston out and everything look good. But if it was mine it would be the first thing I looked at given all your other symptoms, especially if your transmission is between those numbers from that Tech Service Bulletin.
With all that said, I'm not a professional Chrysler mechanic with umpteen years of experience. I'm just a very mechanically inclined shadetree automotive mechanic that knows how to read a scanner and can follow a troubleshooting flowchart.
Best of luck to you.
#46
ok got it down and the o-ring was there.. crap. took off the plate and holy $hit the plastic piston exploded. lots of parts!!!! I wish I knew how to post pics. you wouldnt beleve it. so know to put back together and see what happens. another question. with the piston exploded should I be looking for plastic parts any where else? or run it and do a fluid change in a couple weeks? thanks to all for the help. I will keep you informed.... thanks again
#48
Glad it is running again.
jonc123
09-02-2009 11:37 AM
Mizhan6
10-21-2008 04:37 PM
