Grand Voyager 2004 2.8 CRD "Modine Oil Cooler"
Broke down on the way home Friday. To cut a long story short, it overheated because the coolant was full of oil!! (no water in the oil) My immediate concern was head gasket, but it has only covered 60,000miles. After some investigation and numerous flushes of the coolant I turned my attentions to the oil cooler under the oil filter. Having read post on another site, I bypassed this cooler with some spare hose and ran the engine. Sure enough oil started to drip from the coolant lines on the cooler. I actually removed the culprit to see the internal condition, and it looks fine. But under the pressure of the oil when operating, oil passes through the matrix into the coolant line.
Quick search on the internet and popular auction sites, and found nothing (apart from these oil coolers seem to popular on performance Subaru Imprezas), so it’s a main stealer part.
Unfortunately its £240 and has to be ordered in (unless anyone else knows where to get one?, the one on there is manufactured by Modine). No point in second hand, who knows all long it will last?
So for now I driving with it by-passed, which Chrysler say is ok for a little while……
I did. Found out that I actually had a cooler off a 2.5 fitted to mine, so I had to make a few adjustments to the coolant pipework to get the 2.8 fit. (since the 2.5 verison for £400)
ImageShack® - Online Photo and Video Hosting
2.8 left, 2.5 right
2.8 left, 2.5 right
I've had a look of the oil cooler and it looks a big job, but bare in mind I'm laying down on the floor grrrr if I was going to bypass the cooler will I have to block off the cooler It's self?? Or is it the case of just joing them both? Also do u know a price of a new one?
Is the oil cooler behind the oil filter? If it is, its a really easy job. It's just a matter of removing the oil filter, and then taking off the cooler it's self which secured by a single bolt. That's how it was on my 2005 voyager. Regarding the bypassing I just connected the two water pipes together. Then i looped the oil cooler together with a spare piece of pipe and jubilee clipped up. As for the price it cost me a whole £232. Hope this helps.
Steve.
Steve.
