grand voyager dash dials (uk)
Old 05-04-2009 | 04:53 PM
Marlowe's Avatar
Default grand voyager dash dials (uk)
Hi all,
i have a 2005 grand voyager crd and have an intermittent fault (well i guess it is?) that sometimes when i attempt to start, the dial needles on the speedo & rev counter move and go all the way round then fall back to the zero positions then if i attempt to start nothing happens.
i have put up with this for a while now by switching ignition off and re-trying to start which it will if the needles dont move. But today everytime i attempted to start the needles would move and a clicking sound around dash area was heard! Called out breakdown recovery who got it going by using jump leads... battery is only 4mths old tho.. he did say it could be an earthing problem!! but hasn't a clue as to why the needles would move.
would appreciate any feed back on this
cherrs.
Old 05-05-2009 | 06:38 PM
Merlin's Avatar
The needles do this if the battery is low or has been disconnected and is normal operation, it’s just the dash resetting. The clicking again is normal if the battery is low. Do a search on here, I guess you have a diesel and probably doing short trips. Need to do a battery drain test no more then 0.03 amps after it’s been stood for an hour (needs to go to sleep properly before you test for drain) then I expect you need the battery upgrade or you have a charging fault or an intermittent drain.
Old 09-07-2009 | 09:30 AM
scaryspider's Avatar
Smile This is a common fault see posts
Hi i had this problem and sorted it out others have done the same not all have extended cables though space saver battery is not upto the job
https://www.chryslerforum.com/forum/...ead.php?t=6473
https://www.chryslerforum.com/forum/...4359#post24359
Regards
Peter
dale_hopkinson
05-05-2022 04:21 PM
BrianF
11-12-2013 05:19 PM
pestilance
10-17-2011 08:56 AM
dodger0129
04-06-2011 03:36 PM
jack ger
02-09-2009 04:45 AM
