grand voyager remote problems
Old 06-14-2013 | 02:18 PM
vix2000's Avatar
Default grand voyager remote problems
I have a UK 2005 2007 diesel 2.8 grand voyager. It has the separate key and remote. It started working intermittently, and I disconnected the battery as suggested and it worked. I have been doing this for a few months now, but it has stopped working.
I have replaced the battery but to no avail, (i read somewhere that only certain batteries work, is this correct?).
I have a new key and remote fob but I believe this cannot be programmed without a working remote. Is there anything else I can try to get the original remote fob working please?
As I am disabled this is making life very difficult for me. Thank you.
Old 06-14-2013 | 06:13 PM
vix2000's Avatar
sorry, this is a 2005 don't know where the 2007 came from!!!
Old 06-14-2013 | 07:05 PM
I have replaced the battery but to no avail, (I read somewhere that only certain batteries work, is this correct?).
Try the below .. .. if you are within reasonable distance of me, as a cripplo myself .. .. I'll come and do it for you FOC.
- disconnect the negative terminal from the car battery for 10 minutes then reconnect it
- when you reconnect it the car will make lots of clicks while it checks all of its components
- when its finished its checks, put your key in the IGN and turn the IGN on, do NOT start the car
- then lock & unlock the doors / boot / several times from the KEYFOB then start the car
While its warming up (1) re-set your preferred seat positions with the door switch, your (2) VES settings, and (3) radio stations etc.
- then switch off, get out, and lock the car with the FOB, the locks alarm & immobiliser should work ok
- do they ?
- then unlock the car with the FOB and get in and start the car, it should work now
- does it ?
Last edited by QinteQ; 06-15-2013 at 06:44 PM. Reason: Inserted ........ from the KEYFOB
Old 06-15-2013 | 04:43 PM
vix2000's Avatar
Thank you very much, will get OH to do this and keep my fingers crossed!!!
JoeYuk
03-14-2014 05:46 PM
stewartsoftware
06-26-2012 10:36 AM
tehl1976
10-13-2011 10:06 AM
mbocf
12-17-2009 12:26 PM
veedubmaster
03-24-2007 11:06 AM
