Grinding sound when shutting off motor
Old 10-31-2009 | 05:06 PM
gulfstream's Avatar
Default Grinding sound when shutting off motor
(04 T&C 67,000) When I shut the motor off, there is a grinding sound for about a second. I pulled off the belt tensioner and it made noise when I spun. Figured this was the culprit. Replaced that and also the idler pulley for good measure. Cranked engine, noise still there. Took screwdriver and listened to each component in the serpetine belt drive and everything sounded fine except the alternator sounded like a diesel engine. Low, grinding kind of sound. I assume the bearings are going bad. Is there any way to fix this cheap other than replace the alternator? Thanks for any advice.
Old 11-05-2009 | 09:54 AM
gulfstream's Avatar
Update: I went to a junk yard and found an alternator there. Put it on and that fixed the problem. I would like to replace the bearings in the old one just to have on hand. Has anyone ever changed alternator bearings before. Where would I buy them?
TheAverageDan
06-02-2015 07:31 PM
fcnorwich
10-16-2013 03:48 AM
keyology
08-06-2009 08:39 PM
MikeM8560
05-13-2009 08:46 PM
joshdschwartz
02-05-2008 02:19 PM
