hard breakpedal and ABS light on!
Hi!
Im from sweden so will try to eplan as good as possible.
Got a chrysler grand voyager -93 (automatic) two days ago.
The ABS light on the dashboard is on and the P-break light.
The breakpedal is hard and I must press like hell to get the car to stop.
Sometimes the ABS light turns off and the pedal works as its supposed to.
Tried reseting the databox by removing the batteri cables. The ABS light went off and the break worked. after 2 min the light when on but the brakes worked. After 40 minute drive the breakpedal became hard again and i had to press like the Hulk to stop the car.
THinking if there is a vacuum hose that is broken or a glith in some cables to the ABS pump... any ideas?
Are there any Chrysler dealers is Sweden? I don't get out of USA much
Basically the way the recall is done is they will replace the ABS pump piston...test the system then if necessary replace the whole ABS pump.
Subject: Safety Recall #685 -- ABS Actuator Piston and Pump/Motor Assemblies
Models:
Vehicles Listed Below Equipped With a Bendix-10 Antilock Brake System:
• 1991 Through 1993 Model Year Dodge Caravan/Grand Caravan; Plymouth Voyager/Grand Voyager; and Chrysler Town & Country (AS)
• Late-1990 Through 1993 Model Year Dodge Dynasty; Chrysler New Yorker, Salon (AC), Fifth Avenue and Imperial (AY)
• 1991 and 1992 Model Year Eagle Premier and Dodge Monaco (BB)
Models:
That recall is LIFETIME....period. I've seen some vans have that recall done 3 or 4 times. Doesn't matter if you're the first owner or 20th.
