Headlight Relay
Hi! Thanks for the quick reply. We have been having problems off and on for approximately 15 months. The headlights will sometimes flash off and on while driving and sometimes go off completely and then come back on. If there isn't a specific relay for them, would it be a problem with the headlight switch on the dashboard?
Thank you,
Irishh7
Thank you,
Irishh7
Forgot to mention - we have noticed that the headlight switch on the dashboard has been a little hot/warm to the touch a couple of times when this has happened. Could this mean that this would be the most likely problem? Also, could the power door looks working and then not working be tied into this problem?
Thanks again,
Irishh7
Thanks again,
Irishh7
