Help! 2003 Town and Country Coolant Leak
Old 01-01-2012 | 12:10 PM
djre49's Avatar
Default Help! 2003 Town and Country Coolant Leak
This is my first post on this forum. I recently got a 2003 Town & Country. This may be a dumb question but I am an amateur when it comes to fixing cars...when the antifreeze gets near the top of the coolant tank, it leaks out. I suspect this is causing it to leak while driving, which as a result, is causing the engine to overheat every few weeks. Any help or advice is greatly appreciated!
Old 01-01-2012 | 10:09 PM
i would suggest letting some one with a bit more experience look at your van b4 u over heat it to the point it will become useless.
Old 01-10-2012 | 10:09 AM
Virg///M3's Avatar
I have same T&C ('03) with similar situation. I am trying to understand it but it looks like if you overfill it and after you drive it, it will release the access antifreeze. Mine does not overheat. When you add coolant make sure you do not pass the marker on the tank, which is a little hard to see with out a flash light. If it has the right amount of coolant yet it's overheating, then you should have it checked. Could be many things, air in the system, Thermostat, etc...
Pop45
01-06-2014 12:35 PM
cfa0703
06-03-2013 10:45 PM
xdm
01-21-2011 06:41 PM
CML
06-20-2010 05:30 AM
roy.rut
11-01-2009 08:30 AM
