Help: Disable headlight courtesy feature?
Old 01-22-2012 | 08:56 PM
onetechyguy's Avatar
Default Help: Disable headlight courtesy feature?
Hi, I have a 2008 Town & Country and everytime I use the key FOB to unlock the doors the headlights come on. Does anyone know if its possible to disable that courtesy feature? Any help on how to do it would be appreciated. Thanks
Old 01-23-2012 | 12:23 AM
your owners manual may have that info in there if not the dealer would need to turn it off.
Old 01-24-2012 | 11:41 PM
Gebco's Avatar
Default As per the manual . . .
Press and release the MENU button until Personal Settings
displays in the EVIC.
Use the Step button to display one of the following
choices:
Turn Headlights On with Remote Key Unlock
When this feature is selected, the headlights will activate
and remain on for up to 90 seconds when the doors are
unlocked with the remote keyless entry transmitter. To
make your selection, press and release the RESET button
until OFF, 30 sec., 60 sec., or 90 sec. appears.
Old 01-26-2012 | 01:00 AM
Thanks, I don't have the evic. Should I just take it to the dealer to see if they can disable it?
Old 01-27-2012 | 09:18 AM
andyb2000's Avatar
Even if it doesn't have EVIC, it may have a similar setting. Mine is an older model but it may be similar to that. When you cycle through the MENU option it comes up with ACC delay and HEADLIGHT delay, are those not present when you cycle through the menu?
pete@co.uk
08-09-2009 05:37 AM
kubball
09-16-2007 11:05 PM
Jimbo Asprilla
02-26-2007 11:56 AM
Site News, Updates and Announcements
01-10-2006 03:52 AM
kjohnsonusa
06-27-2005 01:12 AM
