Help, Gearbox oil change
Old 07-18-2010 | 04:11 AM
petewxm's Avatar
Default Help, Gearbox oil change
Hi, Can someone please help, I have a Chrylser Voyager 2.5TD 1999 and took it to get a gearbox oil change but the garage said they could not do it as there is no drain plug, if there`s no drain plug how on earth do you change the oil??? I`m of to Cornwall next weekend which is 300 miles pulling a caravan so I would like to get it changed before I go.
PS its a manual
Thanks for any advice
Pete
Old 07-18-2010 | 07:15 AM
gareth111278's Avatar
A manual? I 'm not sure, the auto has a sump that you remove to get the oil out & change the filter.
i'll have a look in my workshop manual & get back to you.
I wouldn't worry about it too much if you do have to tow with it , its the autos that need regular oil changes as they use the oil to drive the car, thus it gets hot.
Old 07-18-2010 | 07:26 AM
Hi.
I've just looked it says there IS a drain plug , looks like its at the lowest part of the gearbox. Its an allen key type.
Also fill plug on the end cover. Use 5w-30 engine oil, it should need 2.2 litres.
I don't know how to e-mail you just part of the PDF I have , its 1200 pages so too big to send the whole thing i think.
Gareth
Old 07-18-2010 | 07:54 AM
petewxm's Avatar
Hi Gareth,
Thanks for the info, I`ve just sent you a pm
Pete
Old 07-18-2010 | 10:39 AM
petewxm's Avatar
anyone got any pics or drawings of the location, so I can show the garage?
Pete
Old 07-18-2010 | 11:24 AM
Hi Pete Check your e-mail.
Sorry no joy with pics.
I could print & post if you are happy to send me your home address or work address as you've told me you are going on holiday now!!
Old 07-18-2010 | 12:11 PM
petewxm's Avatar
Hi Gareth,
thanks for trying, I`ve just been under the car, sorry dark photos no flash on my phone, is the first pic of the drainplug? and the seconded pic of the where you fill it up? (It has a rubber bung in it?)
Thanks for all your help
Pete
Old 07-18-2010 | 12:12 PM
petewxm's Avatar
Old 07-18-2010 | 12:28 PM
Those look like what you are after, TBH its tricky to get a perception of where what we think is the drain plug is on your car, but if its low down on the 'box its worth a crack. Just take care that 1000 clock springs & ball bearings don't come flying out ! LOL
The drain bung looks quite likely, i'd wip it out & stick my finger in, if its up to the level & the oil doesn't smell 'burnt' I'd recon its OK.
Your user mame? WXM isn't Wreham is it? I'm only down the road in Barmouth.
Old 07-18-2010 | 12:40 PM
petewxm's Avatar
Yeah m8, just outside Wrexham in a place called Rhosllanerchrugog, I`ve been to Barmouth a lot of times, a lovely place. Thanks for all the advice.
Just checked the oil level in the engine after the garage changed it yesterday and the idiots have over filled it, looks like I`ll be poping there tomorrow to get them to drain some out. and while I`m there I`ll point out the gearbox drain plug, the one that they said didn`t exsit. Think its time to find a better garage.
The only reason I want the gearbox oil changed is that you hear all the horror stories on here of gearboxes failing and that the oil needs changing every 20k miles, I`ve done 15k in the car since I`ve had it and dont know what the last time it was changed
Pete
