How to replace backside valve cover gasket on 2001 3.8L T&C
Any way i can replace the backside gasket easily? Read on various posts about tilting engine forward, how is this accomplished? Or should i save myself the agony and let the dealer do it.
RE: How to replace backside valve cover gasket on 2001 3.8L T&C
REMOVAL [ol][*]Disconnect negative cable from battery.[*]Remove the wiper module. (Refer to 8 - ELECTRICAL/WIPERS/WASHERS/WIPER MODULE - REMOVAL)[*]Disconnect spark plug wires from plugs.[*]Disconnect power steering pump supply hose support clip from cylinder head cover (P/S Supply Hose).[*]Disconnect PCV hose from cylinder head cover (PCV Hose).[*]Remove cylinder head cover bolts.[*]Remove cylinder head cover and gasket (Cylinder Head Cover). [/ol]
jconstanza7
05-31-2008 06:17 PM
